Wiring not showing up in in a linked view design option
Hi there,
I have a linked views in my site model to show the RCP wiring. My primary option shows the wiring, but my two other design option wiring does not show up. The light fixtures do show up in the options.
What am i doing wrong?
Hello @Anonymous
The wiring doesn't show up coz, those wires was consider as an annotation lines.
To show up those wiring you have to customized the revit links under visibility graphics (see image) then put in the linked view the Plan where as the wiring was located.
I am already linking the view. It works to show wiring in the primary option. But when I link a design option the lights and switchs all show but not the wiring.
Is there a way to get the wiring to show in a secondary design option?
Do you have a view for each option in the linked file?  Also, the wire for each option in the linked model should be drawn separately for each option view, similarly to annotation.  With that, wire of design options should show in the host views.
