Revit LT Modify Drop Down Menus
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
BiBO_Craig
711 Aufrufe, 4 Antworten
I'm having real issues in that when placing walls etc, or changing values in the properties box the drop down menu's for location, height etc are not showing?  If I start to type while the constraint is selected I can cycle through the options but this is so slow and frustrating.  Tried hardware accerlation on and off, makes no difference.  Anyone have any bright ideas?
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: BiBO_Craig
What are your system specs?  How much free space do you have on your hard drive?  Graphics card driver up to date?
Nachricht 3 von 5
BiBO_Craig
als Antwort auf: Anonymous
Windows Pro 10, 2.6GHz i7-6600U (driver is up to date), 16GB RAM, about 900GB free on HDD.
I have just tried 'Override High DPI scaling behaviour' in the compatiblility properties and this seems to be working for the minute.  After a little more research it seems there is a coomon issue when using a laptop and external screen scaling displays at different values.  My laptop screen was 200% where the external was 100%.  you'd think Autodesk would have released a driver update or something for this by now.
Nachricht 4 von 5
It is a known issue that All Autodesk products want to be at 150% or less on Display zoom.
Not an Autodesk issue but something Microsoft dreamed up that screwed up everyone else.
Nachricht 5 von 5
Viveka_CD
Hi @BiBO_Craig
Welcome to the Autodesk Community!
Are you using a special kind of wall like foundation or structure that tops down?
Please send us a journal file to troubleshoot further and a screencast of how this is happening?
Also please see the AKN article HERE
This happens in Win 10, because Win 7 didn't allow the user to set different custom display values on each monitor.
Please mark this response as "Accept as Solution" if it answers your question. Kudos gladly accepted.
Tags (1)
