wireframe view still hiding elements
Greg.MercurioCB92P
Greg.MercurioCB92P
I have a detail view where the Model Display is set to wireframe. The detail shows the top track of a wall and I should see the outline of the stud below the track. Problem is the last stud is not visible? It overhangs the track slightly whereas all the studs in the middle of the wall are showing up just fine. Which makes me think that has something to do with it being hidden. I tried the Show Hidden Lines tool without success. What could be causing this behavior?
with attachment
Reveal Hidden Elements.
Greg.MercurioCB92P
It's not hidden in the view like you are suggesting. It's being concealed by another element. Wireframe should show the outline of all the elements even if they are behind another one.
