Generative Design not loading
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
lshannonEQEBT
1183 Aufrufe, 5 Antworten
Hello all,
I am having an issue where I try and run Generative Design in 2021 from Revit and it doesn't load but greys out the buttons as if it is loaded. The only way to make the buttons active again is to close the file and reopen. Problem is, Generative Design still doesn't open even after reopening the file and trying again, or after a full restart of my computer. I have used it before and it worked a few weeks ago, so this is a new issue. What could be happening?
Beschriftungen (1)
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: lshannonEQEBT
Have you installed the update?  2021.1
Have you installed any Add-Ins lately?
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/sfdcarticles/sfdcarticles/H...
Nachricht 3 von 6
lshannonEQEBT
als Antwort auf: barthbradley
@barthbradley
I still have to update it, I'm in the version right before 21.9.4. Is this going to be one of those things that when a new update comes out, the older versions are not going to work anymore?
I have not installed any new add-ins lately.
Nachricht 4 von 6
@lshannonEQEBT wrote:
@barthbradley
Dunno.  I just know that another forum member was having the same issue as you, and it was resolved by installing the dot one update.
BTW: I'm talking about REVIT. 2021.1
Nachricht 5 von 6
lshannonEQEBT
@barthbradley
Gotcha. I certainly hope it isn't going to be the case. I will update once I get mine updated and see if that fixes it.
Nachricht 6 von 6
lshannonEQEBT
@barthbradley
So after the update, Generative Design is now loading without a problem. I am now having issues with how it is running, however, so I created a new thread for that (https://forums.autodesk.com/t5/revit-architecture-forum/generative-design-study-results-not-working-...)
