Windows Tag: Sill Height
XXalessio.amodioXX
Message 1 of 10
XXalessio.amodioXX
Hi all,
I want to give conditional format to window tag - Sill Height.
I want the tag show me the Sill Heigh when different than 0. I do not want to show the Sill heght when equal to 0.
Any idea?
Replies (9)
Message 2 of 10
martijn_pater
I think you would do it with a label with visibility parameter which checks a shared parameter value if it's >0.
Message 3 of 10
You can do this through a Calculated Parameter in the Tag Family which evaluates the "Sill Height" Parameter Value.
e.g.: Formula for Calculated Parameter= if(Sill Height>0, 1,2)
Let me clarify: Are you asking if a Tag's Value can be blank if the Parameter Value (Type=Length) it is reading a 0'-0".  If so; NO.  But, the Tag can evaluate the Sill Height in the Project via an IF Statement to return a particular Length Value for True and False.
Message 4 of 10
XXalessio.amodioXX
Thanks for reply. I will try and let you know
Message 5 of 10
XXalessio.amodioXX
Understoo now.
That is a pity. So I think best solution would be a visibility parameter.
Message 6 of 10
Mohamed-Nassar
create label to read it with visible parameter
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
Message 7 of 10
You need diffterent tags, one type shows sill label, the other does not. Sounds like a waste of time for such a minor outcome.
Message 8 of 10
XXalessio.amodioXX
As I said before I makes totally sense use visibility function.
Just wanted to know if woudl have been possible th use of IF Conditiotional (Show Not Show) to not crete 2 Types.
Message 9 of 10
martijn_pater
Maybe only using global parameters... which would defeat the purpose really, better to use 2 types then. You could run a Dynamo script which sets the tag types perhaps based on the values.
Message 10 of 10
XXalessio.amodioXX
It might be an idea, but as @ToanDN said, too much effort for minor outcome
