Windows show on floor below
Marcus.Isacsson
Marcus.Isacsson
Hi fellas!
We have some windows with an alternative coloring below the window, this is done inside the actual window family.
It all worked out great EXCEPT that we just found out that the window shows on levels below (since the alternative color continues below the level above). Eg. level 10 also shows some windows from level 11.
How would you make sure that this doesn't happen? Is it possible with a filter?
