Windows frame is not cut in plan
mahanmotamedi1991
Message 1 of 8
mahanmotamedi1991
Capture.JPGHello. Can someone please explain why the window frame and glass are not showing up in my plan?
1- I have checked the cutting plane level.
2- I checked the visibility setting in my hosting Revit file.
3- I checked the visibility of the elements of the windows family.
None of those could help. Attached you can find the link to the Revit file. Any suggestion is appreciated.
https://we.tl/t-eyU4UMJrpt
Replies (7)
Message 2 of 8
mahanmotamedi1991
Message 3 of 8
hmunsell
I cant access the link you provided (company restrictions). Can you attach the file your trying to provide to the post?  just scroll down in your reply and drag and drop it into the provided area.
Howard Munsell
Message 4 of 8
rxi.gg
Edit the window inside the family called "Huisserie". Activate Shared parameter.
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
Message 5 of 8
mahanmotamedi1991
Thank you for the reply. Yes one of the frames line appears after activating the shared parameter but it is still missing the glass section. Do you have any idea where the problem is? It should look like the following image (This is when I activate wired view mode)Capture.JPG
Message 6 of 8
mahanmotamedi1991
I tried that but for I don't know why for some reasons the file can not be uploaded.
Message 7 of 8
mahanmotamedi1991
Here it is.
Message 8 of 8
Change the family to Generic Models and nest it in a window family (shown below).
Or turn the 3D sweep off for Plan/RCP and use symbolic lines/regions for Plan/RCP presentation.
