Question: Create a multi story spiral stair with landings
6 ANTWORTEN 6
Nachricht 1 von 7
Marcus.Isacsson
958 Aufrufe, 6 Antworten
Hi fellas!
I can't seem to get this right.
I want to create a multi story spiral stair with landings and adequate railings.
How should it be done? When I try it seems to be some errors (especially with the railings)
Beschriftungen (1)
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: Marcus.Isacsson
Something like this?
Nachricht 3 von 7
Marcus.Isacsson
als Antwort auf: barthbradley
Exactly! But with railings! (thats where it usually gets messed up)
Nachricht 4 von 7
I don't know what that means.  Are you talking about inside railing on small radius spirals/winders? Yeah, that's a problem. Probably why you seldom see inside railing on small radius spirals/winders.  Google it.  You'll see what I mean and get some design ideas.
Nachricht 5 von 7
Marcus.Isacsson
I'm thinking about the outer ones, having trouble with those as well using multi story stairs (like yours). Does it work for you if you add railings now? (how should it be done)
Nachricht 6 von 7
It should be done normally: place railing either via place on stair, or by sketch + pick stair as host.  If the railing is identical from one level to the next then place it on one stair of the multi level stairs and be done.  If the railing varies from one level to the next then unpin where you need modifications.
Nachricht 7 von 7
Marcus.Isacsson
als Antwort auf: ToanDN
That's where it doesn't work for me. If I place a railing on a multi story stair it ends up looking out of place. The railing connects vertically between the landings and such. My last try also ended with the railings only going half the way. Does it work 'out of the box' for you? I used Revit 2021.7.
