Windows and doors not cutting curtain wall properly
- Mute
- Permalink
- Report
First I'd like to give a big Hello to the community as this is my first post on this forum 🙂
I am working on an industrial hall which has an insulative metal panels cladding. I created curtain walls, replaced system panels with custom wall panels so I can put windows and doors into curtain wall. So far so good... Then I successfully put windows into these external walls, but then I realized that Revit isn't cutting window openings into panels properly on one of four walls! Three walls don't have a problem being cut for windows, yet fourth wall seems to only cut one panel per window. The same goes for industrial door - when I place them into the wall, only one panel gets cut. On all the other walls, the door opening is cut for the whole door area...
I tried multiple solutions, I mirrored the entire OK wall with windows, I've redrawn the wall with "create similar", I placed the windows one by one, I mirrored the windows from the OK wall, the fourth wall just doesn't want to cooperate... I am out of ideas what to do, does anyone have a clue how to solve this problem?
Thank you in advance 😉
