Placing ceiling hangers at grid line's intersections
7 ANTWORTEN 7
Nachricht 1 von 8
1257 Aufrufe, 7 Antworten
Hi!
I'll need some help from you.
I'm trying to make a Dynamo script to place hangers along my ceiling rails just as shown in the attached image.
The ceiling is a triangular sloping surface modelised as a curtain wall, so I'd like to place those hangers every 3 intersections of the curtain wall's grid lines.
Please help me, my boss is changing them every two days, I need this dynamo script...exempleexemple
hanger locationhanger location
7 ANTWORTEN 7
Nachricht 2 von 8
stevie_kelly
als Antwort auf: Anonymous
Hi @Anonymous,
Great idea! I have written a script for you... I have tested it, so it should work, but do let me know if you have any issues.
I created it in Revit 2018 and Dynamo 1.3.4, and used the Rhythm node package (which you'll need to install if you don't have it).
It's quite self explanatory as I wrote some notes on it, but please let me know if you want some help using the script, or if you need some changes made.
Kind regards,
Steve
Nachricht 3 von 8
mrukhsar
als Antwort auf: stevie_kelly
Hi can you please help me i want to place hangers at ceiling grids
Nachricht 4 von 8
Hi Steve,
I'm trying to achieve a similar outcome. But I have used Sloped Glazing as a suspended T-Grid ceiling. Is there any way of incorporating this dynamo code into my Revit file?
Nachricht 5 von 8
RDAOU
als Antwort auf: Grace.AndersonWBDDB
@Grace.AndersonWBDDB
You had a post started on this subject or am I mistaken
https://forums.autodesk.com/t5/revit-architecture-forum/suspended-t-grid-ceilings-creation-schedules...
Nachricht 6 von 8
Grace.AndersonWBDDB
als Antwort auf: RDAOU
I did but that was for the grid which I have achieved. Looking for solutions to place the hangars and connectors. I'm going through lot of Dynamo tutorials so fingers crossed I can create some kind of solution :gekreuzte_Finger:
Nachricht 7 von 8
RDAOU
In your previous post you wanted something more of a not complicated and user friendly.
Is Dynamo now considered as a solution? if it is the best would be to start a new post with those attachments and there are a few of us on this forum who can help you with a dynamo solution.
Otherwise there is a dedicated forum for dynamo on the following link  https://forum.dynamobim.com/
Nachricht 8 von 8
RDAOU
