window will not open in editor 'cant make cut-out
wisedrawing
wisedrawing
Window family not opening
I can open another project in this same session and it will open the other windows
I can't even get it open to see if the family is broken
all other families open fine including doors and sliding doors in the same wall system
if I select delete element at the bottom of the error message it will let the family open - what did it delete?
when I delete the mullion - window projection lines - they are just symbolic lines - the windows don't cut the wall anymore
I have loaded the windows before and after attempt
any ideas
Nothing comes up with a general search on this
this is what following through with the delete element does, its just left the sweeps:
Simon_Weel
Well, the error pretty much described the problem: there's a problem with the opening cut. So open the Family and delete / recreate the opening cut.
You might want to Audit the family. Right click the family, select Save, save the family and then Open Family, select the family, put a checkmark on the Audit option and maybe it will solve the problem - most of the times it wont'.
wisedrawing
its amazing what posting something does to the brain - I have been at it before and after posting and now with that little hint I went in and deleted the cutting element.
I had to open it separately as you suggested which meant that it did not delete the element
then added the new one and presto
cheers
