Window Schedule
Window Schedule
woodstim
Message 1 of 43
Window Schedule
woodstim
I am making some changes to a house I have modelled. I want to show existing, to be demolished and proposed (new) walls and windows etc.
However, in the window schedule, I cant seem to get it to show the proposed windows. Does anyone know how to do this?
I have got the `to be demolished` and existing windows to show on the schedule, but cant get it to show New or proposed.
Also, sometimes when I place windows, I cant see them in my floorplan unless I high light the wall by drawing a box over it. Why is that?
Tim.
Accepted solutions (3)
Replies (42)
Message 2 of 43
Message 3 of 43
woodstim
Thanks. but I want to show ALL the windows on the schedule, with either existing, to be demolished or proposed by the side of them. I know I can toggle between them and the schedule will change, but I want all the windows to be listed, weather existing, to be demolished or proposed.
Any help much appreciated.
Tim.
Message 4 of 43
Message 5 of 43
woodstim
Thanks, I can do that, but again, you are not showing the NEW windows in the list. I want to show NEW, to be demolished and existing.  But there is not an option on the toggle switch for this.
So how can you show New windows in the window schedule along with existing and to be demolished.
Tim.
Message 6 of 43
woodstim
As you have shown above, you can show Phase created and Phase Demolished, but not New phase??
Message 7 of 43
Wouldn't you want the schedule phase filter set to "None" then?
Message 8 of 43
Tim.
What do you mean?  The first window in the list is an existing window being demolished, the second is an existing to remain, the last one is a new window.  What else do you need?
Message 9 of 43
@woodstimwrote:
...but I want to show ALL the windows on the schedule, with either existing, to be demolished or proposed by the side of them.
Yep, sound like "NONE" is the way to go then.
Message 10 of 43
woodstim
can you show which one you mean I should set to None? As I have done that and it doesnt seem to work. My proposed windows are still missing in the schedule.
Message 11 of 43
What do you mean by "proposed" windows. Do you have a phase by that name? Or are you meaning windows that are in a future phase of construction?
...bottom line: what I'm taking about is the phase that the schedule is reporting on. It has a phase setting just like views do. Sounds like you want no ("None") phase filter.
Message 12 of 43
Set the schedule phase to the last phase of your project, where you created the proposed new window, and set the schedule phase filter to ALL or NONE.  If you still can't show them, share the file so I can understand how your phasing is setup.
Message 13 of 43
woodstim
Ok, ive attached screenshote. So wgat I want is a window schedule that shows all the windows in my house, weather existin, to be demolished or new / proposed. But there is no `All` option in the phase filter for the schedule, so I'm missing windows depending on which one I choose. See below.
So, I would like to see all my windows, 1 to 27 in this case, with the phase listed too. See attached.
Tim.
Message 14 of 43
Sounds like you don't want phase filtering, so set Phase Filter to NONE.  BTW: it's SHOW ALL not ALL.
...on the schedule's properties palette under PHASING category
...I'm looking at your photos and see no schedule. Maybe we're misunderstanding you. Are you talking about Schedules, or trying to show something in the View or on the Tag itself?
Message 15 of 43
woodstim
Hi, thanks. See attached. You will see the schedule is missing windows. I want to show ALL windows and their phase.
Tim.
Message 16 of 43
woodstim
is this what I should be changing? See Attached.
Message 17 of 43
No. If you are truly talking about a Window Schedule (View tab=>Schedules), then look on the Properties Pallet inside a Schedule View itself and you'll see what we're talking about.
...go into the schedule that is shown in your schedule.png above.
...do you mean to create and demolish windows in the same phase?
Message 18 of 43
Here:
By the way, the highlighted windows below should have been created under Existing phase and Demolished under Proposed phase.  What you have there means you installing the new windows and taking them out immediately.
Message 19 of 43
...or paying a contractor to do nothing.
Message 20 of 43
woodstim
See screenshot attached. I have created the window schedule from view/ schedules.
The schedule Phase filter will only toggle between Existing, To be demolished and proposed. So the schedule then reflects that with the windows it shows. But, I want to show ALL windows in the schedule and weather they are existing, to be demolished or proposed. How do I do that?
Tim.
