Window representation
4 REPLIES 4
teresa.afonso
346 Views, 4 Replies
I have 2 door types from the same family, each one with different sill heights. The view range is at 145cm enabling the cut of both, but window 2 has a different representation.
I have also checked the view range in the family, and it seems to be ok.
Does anyone know what can be causing this?
4 REPLIES 4
Window & door families are not cut based on the cut plane defined in project views. Instead they are cut based on the cut plane defined in the family's plan view.
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
The family`s view range is also ok...
in reply to: teresa.afonso
Share the family.
syman2000
in reply to: barthbradley
I am not having the same issue as yours. Do you have plan region within those area? Is the window frame set as nested shared family?
Forma Design Contest
Technology Administrators
