Window Not Transparent
Message 1 of 8
Hello everyone. The windows on my project are all showing not transparent. I tried to edit the family but the family shows ok, everything is working ok into that family, the glass is transparent. So I don’t understand what is happening.
Accepted solutions (3)
Replies (7)
Message 2 of 8
aRcHiTeCt.JM
…hi @Anonymous
…. can you upload the .rvt file
….. it could be couple of issues with that
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Message 3 of 8
Here is one widow from the project. I ‘ve just copy-paste it to a wall to show the problem.
Message 4 of 8
aRcHiTeCt.JM
…hi @Anonymous
…. you are using the window as an existing element of your project
… if you like to change it
… click on the wall (turn it blue)
…. in phasing … change phase created
…. to a new construction
…. that will solve the issue
aRcHiTeCt.JM
REVIT EXPERT ELITE
Message 5 of 8
I didn't know that. Thanks very much. 👍 😁  💯
Message 6 of 8
I'm going to hang around you more often @aRcHiTeCt.JM. You get solution credits for just breathing on a thread. What's your secret?  😉
Message 7 of 8
The secret is he knows exactly when OP posts a question to answer it in a timely fashion, with emoticons for extra icing on the cake .   Try some other posts from OP you will see.  I just leave it here:
https://forums.autodesk.com/t5/user/viewprofilepage/user-id/6528603
Message 8 of 8
Base12
I also found that if you are trying to render a project that has multiple phases, set the Phase Filter to "Show Complete", instead of "Show all".  This will get your existing windows to render properly along with any new ones, and not be "darked out".
