- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I don't understand why the program insists on displaying the windows incorrectly when I already fixed on the floor plans and family. Is this something i have to fix on family editor or on the project? are there some special options or settings to adjust for the legend display? what steps should I follow?
Some windows on my project were not visible because they are way too high from the cut plane. I fixed them by creating some plan Regions and asjusting their view range. Then I edited the Family's cut plane in order to have it visible on the floor plan. The window is looking correct on the floor plan.
Now when i created some legends for the windows, they look odd again , and some parts are hidden.
Both windows are from the same family but the one of the top does not display correctly and is the same window i referred previously. It should look like the one in the bottom
As you can see on the image below i already fixed how the window looks on the plan. I created a plan region and adjusted the cut plane and I also adjusted the cut plane on the family editor.
