Window Gradient shading
Message 1 of 12
My client asked to get glass to look like this photo. Is there a way to do this?
Replies (11)
Message 2 of 12
There is a few approaches to shading the windows that way.  Shaded view would be one. Have you tried that?
...have you tried Shadows On?
...have you tried different Sun Settings (e.g. Azimuth and Altitude)?
Message 3 of 12
Play with the glass material settings: transparency and tint.
Message 4 of 12
I Have played around with it, graphic display options, the materials. only seem to get 1 shade/1 color
Message 5 of 12
Was that image created in Revit?
Message 6 of 12
I have tried the Shaded view - no solution
I want the glass to display the same on every window, every side of building, so sun setting/shadows-no solution
Message 7 of 12
I have no idea, I was given to me through a pdf that file called scan. Trying to mimic the window gradient/shading
Message 8 of 12
You can have some gradient form the material as a whole but I don't think it can be localized to each window like what you show.
Message 9 of 12
Corsten.Au
there is a gradient options in material...use that.. apply to Glass of the window.there is a gradient options in material...use that.. apply to Glass of the window.
Corsten
Building Designer
Message 10 of 12
 OMG gradient one of the patterns. Thanks @Corsten.Au
Message 11 of 12
Michal_Kaminski
Is there any way to achieve it, in not realistic views (hidden lines / shaded / consistent)? This is something that I really need...
Message 12 of 12
rafalee
Did you find any solutions for that?
