Since I've just reloaded Revit Lt 2019 onto my computer I'm having trouble dragging ANY views (either detail views, drafting views, elevations etc.....) onto sheets. It's very hit & miss; I'll try to drag a view about 10 - 20 times before it gets onto a sheet. I've been using Revit for 10 years & never came across this before, nor have found any forum posts addressing it. Is it a recent bug in the current version? I've thought perhaps it was my mouse button setting but that seems to be all in order. Can anyone help?
hello, have you try to repair or clean uninstall and reinstall again the program it could be some files are corrupted and see if helps. thanks
Are you upgrading previous versions to new software??? If so, I feel your pain. I does seem take longer to upgrade with each new release. Before it took 1 cup of coffee, Nowadays, it takes liquor. Kidding, Partially.
Try a different mouse.
I'm going to try re-installing first. Just checked Revit 19 on my MacBookPro laptop & have no probs with dragging the views; suspect something must have gone wrong with re-installing Revit on my iMac. I already have a good Logitech gaming style mouse that I did research on as one of the best for using with Revit; I've been using the mouse for about 2 years with no probs so far.
I was already using Revit 2019 & had a major computer fail when starting back at work after Christmas so had to take to Apple for repair then reinstall everything. Up to my third coffee this morning; must be a designer thing - addicted to caffeine!
