While attempting to work with various Revit Materials, I inadvertently changed all of the door jambs in the project to white. The door and door trim is still wood (brown) but the jambs have been changed to white.
Thank you
Is the door using Revit out of the box door? Often the default Revit door don't have frame and you have to add it in.
As for window, you may have to modify the window family to get GWB to wrap. Upload the family.
Sounds to me like you are in part asking asking Wall Wrapping. You can drill down from here to learn more:
About Layer Wrapping | Revit Products | Autodesk Knowledge Network
You may find this video helpful as well...
Revit Wall Wrap Closure - A How To Guide | Revit Products | Autodesk Knowledge Network
...I will point out also that we typically model Head, Sill and Jamb "Wraps" (e.g. Floor @ Head and Sills, Walls @ Jambs), primarily because Wall Wraps have no "BIM" Value. The are essentially cosmetic only. They don't schedule and they are difficult to dimension properly. FWIW.
Attached are the door and window families. Both are "default" Revit. The Window I did already start to modify to remove the head and two jamb trims. The door has NOT been modified.
What are you having issues with? Assigning Project Materials to Sash, Glass, Trim, Door and Frame Family Material Parameters? Or to the exposed Wall at the Door Insert? If the Door, try using the Paint Tool to apply a Material to those Wall exposed surfaces.
I should break this down, as there are multiple questions...
The doors, the jamb material has been changed from wood to white, and I would like to change it back...
See the red arrow in the following image, how do I change this from white back to the default Revit wood material...
I think what's going on here is that you are a bit confused about where the "color" is coming from. Your screenshot is showing the View in a Realistic Visual Style. Realistic Visual Style is displaying the Materials as per the the Materials' Appearance Tab settings. Change the View to Consistent Colors Visual Style and the Materials display as per their Graphics Tab settings. Am I getting warm?
Yes, that is all correct. I think the issue is (the part I did not understand) the built in Revit doors don't have a jamb. The door takes on the opening of the wall (it appears), instead of having a jamb. Here is a breakdown with just some simple material changes and paint to illustrate...
