So it will show that the rooms are bounded, but won't do the color fill because it also says that they aren't.
I am not entirely sure what I am missing. The first floor worked out just fine.
Thanks in advance, I greatly appreciate any help 🙂
First Floor:
Solved by ToanDN. Go to Solution.
Hmmm I had Lightweight Concrete on a Metal Deck.
I just changed it to 12" Generic Fill.
I unchecked the room bounding for 1 room and tried to retag it, ran into the same problem 😕
You use a roof in lieu of the floor and it is sticking above the level, interfering with room creation. Set that roof to non room bounding will fix the room issue but if you want to model it as a finish layer then it is way too thick. Better fix it. Cut a section and you will see.
@Anonymous wrote:
Bahaahaha
What does "Bahaahaha" mean? Google Translate can't even figure it out. Is it Epilepsy? Haven't been there myself, but I hear it's a pretty nice place to visit.
