Message 1 of 12
- Mute
- Permalink
- Report
I have two structural columns placed one atop another. The top column is a wood member (6x6) while the bottom column is a concrete member (12" diameter). Looking at it in 3D I can see both as they should be. However, in my floor plan view where I want to see them also, so a square is inside a circle, I only see the concrete column (the circle). When I try to select the wood column I can only do so at the element's center, not at any edges. Also, I can see the wood column when I click + drag to select both objects, but when I deselect I once again cannot see the wood column. I can use Linework to manually show each wood column but I would rather not do this as I imagine the wood column should show up on its own. My Visibility Graphics and my View Range are set up so the wood column should be visible so those aren't what is making the wood column invisible. Is this a default setting hard-coded into Revit when columns are stacked atop each other? Please help me understand why I cannot see the wood column.
