Why the home page is different and so cannot find the architecture template
Hi, I want to open the Architectural Template in Projects file as shown in the second black screenshot. But my home page is the first one that I cannot find where it is. Did I miss download that? Also I don't know why the Home Page of Revit is different? If they are two different versions, please tell me the names of them seperately. Thanks a lot!
David_W_Koch
Or select the New button under Models, to get a dialog with a drop-down list of the template files that you have set up on the File Locations page of the Options dialog.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
ennujozlagam
you can refer to AKN article and se if helps. thanks
Thanks! Now I download the missing template then problem solved. Though the page is still white but seems that it has no influence.😉
Hello .
I have the same two of your problems . Did you solve those? If so can you please show me the way?
Hi now my revit homepage is still white but it doesn’t influence normal using. I
think you have missed something and can try download the templates from revit website again. The downloaded architectural template may be named differently, just open the downloaded templates and search for the one you need.
