Why Revit didn't ask to change the views name?
Message 1 of 9
I have a building with Three levels. I want to change the name of the levels so the associated level with the view is different. when I changed plan 1 to plan 1x Revit didn't ask me if I want to change the associated plans but it did when I changed plan 2 to plan 2x and plan 3 to plan 3x. I wonder why and how to fix it that Revit ask me for plan 1 also. Thank you
Replies (8)
Message 2 of 9
My guess is that you don't have corresponding Level and Views.
Message 3 of 9
I have
Message 4 of 9
If a view was renamed to differ from its Level name then revit won't ask you again when you rename the level.
Message 5 of 9
it is the same name plan 1
Message 6 of 9
Honestly, I've encountered such behavior on occasion before. I've never spent the time to troubleshoot it though. I just figure it's a loose nut behind the keyboard and move on.
...Maybe they aren't named EXACTLY the same?
Message 7 of 9
I will not consider so.
Message 8 of 9
It could be renamed to plan 1x then back to plan 1.  If you can't live without the name association, just delete that view and re-create a new plan view for that level.
Message 9 of 9
@Anonymous: Do you have a sh*t-load of views to rename. You might be able to manage the task more efficiently through a View List Schedule.  FWIW.
