Why I can not add ceiling?
8 REPLIES 8
Message 1 of 9
mwang7DKXEF
436 Views, 8 Replies
mwang7DKXEF
           I can not add ceiling panel?
Thank you so much
Thank you so much
8 REPLIES 8
Message 2 of 9
in reply to: mwang7DKXEF
Go to Architecture Tab > Set Work Plane and make sure it is set to the Level.
Message 3 of 9
mwang7DKXEF
in reply to: ToanDN
mwang7DKXEF
Thank you so much for replaying.  But I still can not make it work. Could you tell me more?
Thank you again
Thank you again
Message 4 of 9
ralphdenhaan
ralphdenhaan
What @ToanDN mentioned should work. If it's not working in your case, you can delete the view and create a new Ceiling Plan.
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
Message 5 of 9
mwang7DKXEF
in reply to: ralphdenhaan
mwang7DKXEF
Thank you. open " Set" can see other ceiling panels, but it does not allow I create a new ceiling panel.
Thankyou
Thankyou
Message 6 of 9
Set work plane then pick the Level. Please.
Message 7 of 9
mwang7DKXEF
in reply to: ToanDN
mwang7DKXEF
Sorry, I still do not understand. Could you show me a video?
Thank you so much
Thank you so much
Message 8 of 9
Thank you so much
Pick the Level of that Ceiling Plan view.
Thank you so much
Message 9 of 9
mwang7DKXEF
in reply to: ToanDN
mwang7DKXEF
Than you sooooooo much😀
Now it is working.🤝
Now it is working.🤝
