why don't wall sweeps seem to work at corners?
svalente9GJKH
svalente9GJKH
When I try to add trim to a corner, Revit can't create it. If I move the sweep over to be off the corner, it doesn't create it.
How can I correct this?
Yeah, that's always been a little tricky. You need to adjust the end of the main wall sweep slightly by dragging the blue grip.
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Revit-M...
Are you talking about vertical wall sweeps?  If so, change the Wall Corner Joint to Miter then you will have an easier time placing corner trim.
