As shown in image, how do you force a room to go all the way out to the curtain wall so that the red area is also included?
When you have several of those, that is no small amount of area.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Edit the wall profile, or add a vertical opening cut, to create an opening at the wall base matching the width of the curtain wall.
