Why doesn't roof bound room?
5 REPLIES 5
kgatzke
2557 Views, 5 Replies
These roofs and floors have the parameter for room bounding checked...
so why don't they?  There are no gaps so I'm guessing I have something toggled wrong.
More importantly, if room bounding floors and ceilings don't actually bound rooms, then how do I model rooms that flow into spaces above and around other rooms?
5 REPLIES 5
in reply to: kgatzke
Change Room/Space Computations to Calculate Volumes.
kgatzke
in reply to: ToanDN
That fixed the rooms under the bleachers but there's a problem with the stairs at either end of the bleachers.  They are not room bounding, and thus overlap between the pool room and stairway room under the stairs occurs.
If I understand you correctly, you can create a sloped ceiling under the stair and set it to bound room.
kgatzke
in reply to: ToanDN
There's no ceiling under the stairs.  It's all monolithic cast-in-place.  I could create an invisible ceiling but you always see the cut lines in sections and such.  Thank you.
That's what I mean. Create a ceiling to bound room and hide it if you don't need to see it.
