Generic Template Revit 2019
Hi, does anyone know how to access the GENERIC TEMPLATE on Revit 2019??
I only have the option for Construction, Architectural, Structural, and Mechanical Templates.
My professor is asking us to use the GENERIC one for our current assignment and I can not find it.
HELP!!
aRcHiTeCt.JM
.... the name for the GENERIC in REVIT is DEFAULT
...... metric template
.... imperial template
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Select None from the dropdown list of template then it will bring you to the next window to choose the system of measurement.
aRcHiTeCt.JM
.... the problem with your solution is that the template will be totally empty
.... if you don't know REVIT pretty good you will be having thousands of issues
.... these are super basic templates
aRcHiTeCt.JM
REVIT EXPERT ELITE
