These roofs and floors have the parameter for room bounding checked...
so why don't they? There are no gaps so I'm guessing I have something toggled wrong.
More importantly, if room bounding floors and ceilings don't actually bound rooms, then how do I model rooms that flow into spaces above and around other rooms?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
That fixed the rooms under the bleachers but there's a problem with the stairs at either end of the bleachers. They are not room bounding, and thus overlap between the pool room and stairway room under the stairs occurs.
There's no ceiling under the stairs. It's all monolithic cast-in-place. I could create an invisible ceiling but you always see the cut lines in sections and such. Thank you.
