Why does Revit only get 85-90% the way there w/ typical graphics/ annotations
Message 1 of 38
Revit can do so much, yet it never seems to close the deal.   Whatever graphic representation of the model used or added annotations, it never creates a complete quality graphic drawings in somewhat of a straightforward manner.   The last 10-15% always requires enhancement, lies, cheating, or work-arounds.   So tired of trouble-shooting !  I sure would like to be productive in my work.  This is a constant fight.
Replies (37)
Message 21 of 38
Things change, and then they don't. Not too many yet putting together a building without paper documents. That change may come but it ain't here yet.
Message 22 of 38
RobDraw
@Anonymous wrote:
My gridlines bubbles periodically get all screwed up, don't know why. I have made no modifications to gridines (that I was aware of) that should lead to this. It happens too often. Pinning and locking doesn't seem to make a difference. How can I keep the grids, alignment and bubles from changing once they have been set. I am the only one working on the project. I'd appreciate your opinion.
I've never seen that happen even when running coordination reviews. Has to be user error.
Rob
Message 23 of 38
User error for sure, but somehow I think Revit is trying to think for me in some manner too. I've heard dragging a crop window around and crossing a gridline can trigger such things but it only effects some of the gridlines not all of them.
Message 24 of 38
georgehobel
Man you guys are brutal..... but not as tough as my wife... she makes me walk when I run out of gas
George Hobel
Reflections of Charlotte
Residential Building and Design
Message 25 of 38
If someone unknowingly stretches the 3d extent of the grid in a different view thinking it is just the 2d extent then it can screw everybody else.
Message 26 of 38
RobDraw
Okay, get that one out of the 10% to 15% graphical inadequacies of Revit.
Next?
Rob
Message 27 of 38
"Unknowingly" is the key word there. Is there any way to prevent it ? lock down the grids in particular ? other than "just don't unknowingly do that in ANY of a hundred views". No sort of management control of critical items ? There's just too much opportunity to unknowingly screw things up. I manage to find the ways.
How would I know the 3D extent of a grid ?
Message 28 of 38
chrisplyler
Re. the gridlines... Wow, I've not heard of that problem before. If you are absolutely the only one to work in the file, then the only thing I can think of is changing crop regions in a view where they are 3D, or assigning/unassigning them to scopeboxes.
I actually use scopeboxes just for the benefits of making grid bubbles line up consistently across views.
What else?
Message 29 of 38
RobDraw
Starting another thread for that topic will get you better responses.
Next?
Rob
Message 30 of 38
chrisplyler
Yeah let's turn this thread around from bickering over a complaint to something useful. Let's hear some more of the specific issues and see if we can't help shomberg push his car from the 85% point to the 95% point, huh guys?
Message 31 of 38
Yes.  3D extent shows an hollow circle with "3d" next to it.  2D extent shows a smaller solid dot with "2d" next to it.  If they read the basic manual of the program they would have know the difference.
http://help.autodesk.com/view/RVT/2016/ENU/?guid=GUID-4E36EDA0-2F4E-4619-B568-AC758E8D9770
Message 32 of 38
Corsten.Au
Hi..
Try this..
1. Plan View Place the grids..
2. Section View : Drag them crossing all the levels.
   ( Grids are a combination of 2D and 3D ), if one grid doesn't cross for ex" Basement Level 1, then
  it wont show up in Basement Level 1 Plan..
3. Elevation and Section : CROP the view the way you want extent wise...this will fix
  the grids automatically...if you are not happy with the grid bubble location, then edit the CROP, not bubbles or grids.
Idea is never ever drag Grids, it just shows up correction as long as you CROP the views..
whether its plan, elevations, section etc..
NOW coming to the second part... If you ever need to convert the grid dragging point 3D to 2D to manually
extent or clean up the overlapping bubble.. then you are on your own..any adjustment like these wont update entire model.
its view specific..
this would help you understand Grids behaviour..
Corsten
Building Designer
Message 33 of 38
RobDraw
I'd love to discuss how to control grids in a different thread because the OP has a number of complaints about Revit lacking in the graphics department that have yet to be addressed, but seems to be hesitant about listing them.
Rob
Message 34 of 38
RobDraw
I'm glad to see that being able to control grids covered that 15%. You are truly one of the lucky ones.
Rob
Message 35 of 38
shubham_shri
If you fill your drawing with too much detail then it will increase the size of the file as well hence better fill only those details which are necessary
Shubham Shrivastava
Autodesk Certified Professional for Revit Architecture
If you find my post helpful, feel free to give Kudos
Message 36 of 38
No, it didn't cover that 15%. I just needed to shut down this conversation string. I had no idea what I would unleash.
Message 37 of 38
georgehobel
And now that's all been unleashed....we anxiously await the release of the memo.🙃
George Hobel
Message 38 of 38
RobDraw
Guess what, you can't shut it down.
I think the real problem is that you couldn't back up your rant with anything substantial, as you couldn't even provide one example of how Revit comes up short on graphics when there are a lot of them, some of which you wouldn't even come across.
Rob
