I use Revit 2018. The toggle in the bottom right to turn off/on SELECT ELEMENTS BY FACE seems to apply only if the face has no surface pattern. When I have this setting off, but the floor face has a pattern (lines of a wood floor) the floor is the selection option even when I hover away from the floor edge. My only work around has been to turn off the floor's surface pattern while I'm working in particular views.
Any way to turn of SELECTION ELEMENTS BY FACE if they have a surface pattern?
