Announcements
Why columns not show up in structural plan view
Anyone know why copied architectural columns not show up in 1st or 2nd floor structural plan. But same type of columns show up in ground floor structural plan and other floor plan. The only way to see to give negative base offset to this columns even though line weight for columns not matching with walls.  Please find the attached photos for your information.
Thanks & regards
ShafafGround floor structural plan which shows columns with same line weightGround floor structural plan which shows columns with same line weight1st floor structural plan which not showing columns1st floor structural plan which not showing columns1st floor architectural plan which showing columns not matching line weight with walls1st floor architectural plan which showing columns not matching line weight with walls
Replies (16)
Bottom picture looks like underlay. Middle no underlay. Top normal. When you copied the columns, did you select underlay column in view and use clipboard copy-paste to level selected method. I suspect you have 2 columns overlapping each other; the source and the copy.
ennujozlagam
hello, have you try to select the columns and change the height instead of depth. thanks
@Anonymous
Can you cut section to show where the columns are?
cbcarch
Check this:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2014/EN...
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
In all views underlays are none. And I did copied ones only. please find the attached photos2018-05-21 (4).png2018-05-21 (5).png2018-05-21 (6).png
I tried, even though line weight for column not same as nearby walls. please find attached screen shot.2018-05-21 (7).png
Can you share a Section Cut view showing the columns on all the floors. When you print screen, please have the Column highlighted (the one not showing up in plan view), and include its Properties alongside the Section Cut View in the screenshot.
@Anonymous wrote:
Am I seeing Ground, 1st, and 2nd levels?  Also, for the structural plan views where the columns not shown, I can't see the view's properties because you highlight a revision cloud.  Can you show the view's properties of that view?
....and properties of Column(s)
Please find the attached screen shot for cut section as you requested.2018-05-22 (1).png2018-05-22 (2).png2018-05-22.png
...I'm stumped. Should we break out Munkholm's List of 33, @ToanDN
No.  The columns are Architectural columns, not Structural columns.  The Columns category maybe turned off for Structure plan views.
@ToanDNwrote:
The columns are Architectural columns, not Structural columns.  By nature, they are not supposed to show on Structure plan views.
What?! You totally lost me. "Not supposed to show"?
I reworded my statement.
...okay then. #2 on Dave Jone's (not Munkholm's) list of 33.
https://www.revitforum.org/tutorials-tips-tricks/441-cant-see-view-heres-33-reasons-maybe-why.html
...so the remaining question is: why one view shows Column half-toned when there's no underlay in the view. Additionally: why is it impervious to Linework Overrides?
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
