Why can't I select all elements in a view to edit the properties of.
svalente9GJKH
svalente9GJKH
Sometimes when I "select all instances visible in view" the properties become greyed out and I can't select anything to edit.  When I select a few of these item individually holding shift, I can edit the properties.
What can I do so that I can edit all?
What are you selecting?  Maybe a selection set filter would be better.
Help | Work with Selection-Based Filters | Autodesk
L.Maas
It is possible that the selected element is part of a group or assembly. In that case some or all of the parameter values can not be changed
Louis
Please mention Revit version, especially when uploading Revit files.
