why can I not add elements to a design option (file posted)
svalente9GJKH
Message 1 of 9
svalente9GJKH
In the attached project, if you go to the design option "WALKOUT DOUBLE DOOR" when
I try to model in elements in the basement area, nothing shows up.
If you go to the design option "FULL NON WALKOUT" you will see a bathroom in the basement.
I am also trying to copy this bathroom and paste into the "WALKOUT DOUBLE DOOR" option but this won't work?
Any ideas?
Thank you
Replies (8)
Message 2 of 9
You would make your life so much easier if you Dedicated Views to Design Options.  Dedicated View are an integral part of the Design Option workflow.
Dedicate Views to a Design Option | Revit | Autodesk Knowledge Network
Message 3 of 9
I see bathroom fixtures in both Dedicated Views, so I'm lost as to what the issue is.
Message 4 of 9
svalente9GJKH
noted...will use this going forward.  Although why not just create groups and hide/turn on by view.
On another note,  I accepted the primary option as "WALKOUT DOUBLE DOOR" so no more design options,
I still can't get anything I model to show in that bathroom area.  Why might this be?  Don't think it view range related...
Message 5 of 9
mhiserZFHXS
What is it telling you when you try to add to a design option?
Message 6 of 9
Sorry @svalente9GJKH, I'm having trouble following. Can you set up 2 Dedicated Views like I'm showing above and let me know if that resolves anything?
Buy the way, I did notice you had the Topography Category turned on in the View, so I turned it off.  If you do the same, does that resolve anything? Like I said, I'm not sure what you are trying to resolve.
Message 7 of 9
svalente9GJKH
I tried yes.  The bathroom shows when I select "FULL NON WALKOUT" option
When it  set it to "WALK OUT DOUBLE DOOR" option, the bathroom disappear and I can't even add a new bathroom in the area
Message 8 of 9
The bathroom shows up here in both DOs.  Look at my screenshots above.
Make sure the "Basement Finish: Finished" DO it turned on.
Message 9 of 9
svalente9GJKH
oops  you were right, it was the topography on!     good lesson on options that I will use though, thank you
