Why are section cuts not showing in Revit?
svalen
svalen
I have cut 2 sections, they show is some plans but not all.
In the plans where they don't show, the category is not turned off, and I have also
turned off the view crop. I did not hide them individually.
Why would they not be showing on some plans>?
ska137
check the scale, match the scale of the view in question with the view where the section is showing.
on section itself, check the property "Hide at scales coarser than"
RSomppi
Another possibility is the vertical extents are not within the view range of the plans.
