Where to find Revit 2020 install files?
bimmanagement8TDXS
bimmanagement8TDXS
They do not seem to be available in the Account Management portal.
According to T&Cs we should be able to use any version from 2024 + 5 years back. But 2020 and 2019 files are not available.
Does anyone know where to download them from?
Thank you
loboarch
I am not sure who/what T&Cs are, but in the past support is offered for the current release, and 3 back.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
DarrenP
read this:
Product versions four to five years back
  1. Sign in to Autodesk Account at manage.autodesk.com.
  2. Click the Autodesk Assistant icon (question mark in bottom right corner).
Note that support, including technical support, software updates, and hotfixes, is only provided for previous releases up to three years back.
pulled from here: https://www.autodesk.com/support/download-install/individuals/configure-install/download-previous-ve...
DarrenP
handjonathan
Hi @bimmanagement8TDXS
Thanks a lot for posting your question to the forums!   Has the solution suggested by @DarrenP helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
zacPBQT7
Community Visitor
Community Visitor
This was very helpful! Thank you!
