Where To find Reference Plane Instance and Remove
I am trying to reduce a bloated project model built by a fellow staff member in Revit 2017.
Using Ideate Explorer, I have identified over 950 "Reference Plane Instances".
I can't single them out, I can't find them anywhere, Revit can't "Show Me" where they are. I can get their ID number by Revit can't find them anywhere.
Even when Ideate Explorer selects them I can't delete them.
What the heck are they and how do I get rid of them?
constantin.stroescu
Doesn't it work ,if you select all and then apply Filter?
Constantin Stroescu
Alfredo_Medina
As I have commented before, this should be written in the project's BIM standards: important reference planes should have a name and should be in a dedicated workset. Any reference plane that does not comply with this should be deleted. This is just bad practice, to fill a project with a thousand reference planes without any classification. I assume you can find them with select all in project, but that is not going to tell you which planes are important and which are not.
Can Ideate Explorer distinguish between reference planes placed in the model versus placed in in-place families versus place in loadable families?
MacurFZGVK
Select all option is not working for reference planes, it is grayed out.
I guess the only option is to try with dynamo.
