How do I download a Stereo Panorama, so I can use it when I am not connected to the internet. There is an option for it in the menu (See Image Below). But it doesn't work. When you click it nothing happens. How do we get this option to work? Thanks.
Nardo
Gelöst! Gehe zur Lösung
Gelöst von john.vellek. Gehe zur Lösung
Hi @Anonymous,
This is strange as I can download mine without any problems. I do mine from the thumbnail view and hover over it to see a drop down menu. From there I can select the download Stero-Pano as Zip.
Is this a different process than you are using?
John
That is the exact thing that I was doing. I had tried it on a couple of different occasions. Since you said that it should work, I tried it again, after a full reboot. It took about 5 minutes but I did finally get a download window and I was able to download it. I probably gave up too soon before. I didn't think it would take so long.
I hope it keeps working. Thanks
Nardo
Nardo - I am glad you got it to work. Sometimes those files are large enough that it can take a while. Thanks for being patient.
