Where to Find Detailed Door Family
sonyablade2010
sonyablade2010
Dear ALL,
As the topic describes where am I supposed to find the detailed door family which has customizable panic handle, door stopper/pump, door handles, hinges, door frame profiles to be seen from level view and all other details which makes it nice and elaborated ( similar and not less than those shown at the attached image). I already looked at the revitcity.com, and bimobject.com but could't detailed that will suit my needs. Your guidance will be appreciated.
L.Maas
As Revit is used for modelling buildings the items are usually less detailed (to prevent large file sizes and performance issues).
So the families tend to be less detailed and when needed arw supported by other documents (datasheets, detail drawings). Also when it becomes more detailed they tend to be manufacturer specific. In that case you could look at door manufacturers websites. Even then I do not expect that level of detail.
Then you are left with building it yourself. Note that Revit has a limit of minimum linelength of about 0.8 mm. So if the profile is very detailed you still might run into issues of building the family.
Louis
Please mention Revit version, especially when uploading Revit files.
