Weekly New Knowledge Articles by Support team | Sep 7 -13th, 2022
0 ANTWORTEN 0
Nachricht 1 von 1
lim.wendy
97 Aufrufe, 0 Antworten
Knowledge articles written by our Revit support team to resolve the problem on your own. There're couple of incidents reported, do take a look at them for possible workarounds.
Published Date
Summary
Knowledge Articles
Incident Logged
12-Sep-22
Users reported that  "Disable shared position" message shows repeatedly when trying to disable shared position in Revit links. Every time you change the place of a link that had a previous shared position to "not shared", a message will display asking to disable shared position.
"Disable shared position" shows repeatedly when trying to disable shared position in Revit links
Yes
09-Sep-22
When trying to bind Revit links into a Revit model a "serious error" appears.
Binding link makes Revit crash
Yes
09-Sep-22
How to convert linked IFC into RVT model in Revit?
Convertion of linked IFC into RVT model in Revit
No
09-Sep-22
IFC cannot be opened properly as only lines are visible in Revit 2020.
IFC cannot be opened properly in Revit
No
09-Sep-22
Topography created from CSV is not aligning with survey coordinates in Revit.
Topo is not aligning with survey coordinates in Revit
No
09-Sep-22
What are the recommended ways to work in Revit on a single cloud workshared model with other external contractors? How to control the changes made by them?
Control of changes made by external contractors in a single cloud workshared model in Revit
No
08-Sep-22
Users reported that Project Information parameter value is empty for Varying Rebar set in multicategory schedule in Revit.
Project Information parameter empty for Varying Rebar set in multicategory schedule in Revit
Yes
08-Sep-22
Users reported that roof area and volume not correct in exported IFC from Revit.
Roof area and volume not correct in exported IFC from Revit
Yes
08-Sep-22
Turning on or off the 3D Grids affects the display of Ambient Shadows in the Revit model.
Yes
08-Sep-22
What are the reasons for the changes or lack of changes in system requirements between successive versions of Revit?
What are the reasons for the changes or lack of changes in system requirements between successive ve...
No
07-Sep-22
"A Pad can't extend beyond the edge of a Toposurface" when adding a Building pad in Revit to a linked Topography from BIM 360.
"A Pad can't extend beyond the edge of a Toposurface" when adding a Building pad to a linked Topogra...
No
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
0 ANTWORTEN 0
