where is installed the new revit 2026.2 expanded Residential Content Pack
PAarchitects
Message 1 of 8
PAarchitects
I can't finfd it in my computer
where is installed this revit 2026.2 expanded Residential Content Pack
it is not showing in the C:\ProgramData\Autodesk\RVT2026 librares, but it is showing that is already installed.
can anyone give me a specific path........
thanks
Replies (7)
Message 2 of 8
PAarchitects
found it:
C:\ProgramData\Autodesk\RVT 2026\Libraries\English-Imperial\US\System Families
Message 3 of 8
Paul_F_Aubin
It gets merged into the existing US Imperial library. You will find new items in several folders in that location. This includes Casework, Specialty Equipment, Furniture and even a new Door family and some electrical items.
Also as noted by @PAarchitects below, there is are two library files in the System Families folder. These are project files that contain examples of all the items in the content pack. Just open it like any other project.
Paul F Aubin
Author/Consultant
Check out my books and training videos
paulaubin.com
Message 4 of 8
MelissaBaz
Observer
Observer
Message 5 of 8
Paul_F_Aubin
MelissaBaz, Everything is installed correctly. The residential content pack includes families in many different categories. There is only one new door family. What you are seeing in your screenshot is this door family and its accompanying type catalog.
As for the System Families folder, you must use the Open command in Revit, browse to this folder and then open the file like any other project file. This folder does not contain families to load. Instead, you open the project and you can see many of the content items already inserted. You can also just copy and paste from this file as an alternative to Load Family.
Paul F Aubin
Author/Consultant
paulaubin.com
Message 6 of 8
Paul_F_Aubin
Please note the message in my screenshot that indicates you must open the file "read only" to continue. This is normal.
Paul F Aubin
Author/Consultant
paulaubin.com
Message 7 of 8
mramosHPKWY
Community Visitor
Community Visitor
I'm missing the "Libraries" folder. Any idea where this could be installed? The only folders I have at C:\ProgramData\Autodesk\RVT 2026 are: Dynamo, Recent, and UserDataCache.
Message 8 of 8
Paul_F_Aubin
This means you probably don't have any libraries installed. They must be installed separately. When you install Revit, it does not install the libraries unless you choose that option. You can go to your Autodesk account and find the libraries to install there.
Paul F Aubin
Author/Consultant
paulaubin.com
