imported revit link has REALLY thick lines
2 ANTWORTEN 2
Nachricht 1 von 3
stevensonJQWEF
213 Aufrufe, 2 Antworten
Hello all,
I have imported a revit project for my interior walls.
However in the floor plans the lines appear really really thick.  I have checked in the object styles and the line weight of every single line is set to thickness 1.
It also doesnt seem to make a difference in visibility graphics when I customise and set the lines of doors and walls to 1- nothing changes.  Plus even if this did work then it seems that it would be a very tedious thing to do.
Note, when I import this model as a group, then the lines appear as normal.  But I want it linked with the project instead, so that i can switch between a couple of different models.
Does anyone have an idea of how I can fix this?
Thanks in advance, nina
2 ANTWORTEN 2
Nachricht 2 von 3
Simon_Weel
als Antwort auf: stevensonJQWEF
Check the Visibility / Graphic Overrides panel, tab Revit Links.
Nachricht 3 von 3
stevensonJQWEF
als Antwort auf: Simon_Weel
hi,
as i said i have tried this and it doesnt do anything.  Even then I would have to do that for ever single view??
