when printing sheets to pdf, revit realistic view is printed like wireframes. why?
chhuanmawia18
chhuanmawia18
when printing sheets to pdf, revit realistic view is printed like wireframes and sometimes it is not,and is printed like the way it is in the view(ralistic view), with the same settings and same print settings. what could be the reason for this.
Which PDF printer?  Can you use Revit's Export to PDF instead?
chhuanmawia18
is there a separate export to pdf option in revit because i have not noticed it. Under export option there is no pdf option , the option is available from File>Print>pdf .Anyhow, the problem is that it occurs sometimes, even while printing in the same pdf, one sheet may get exported as a realistic view and another sheet may be printed as a wireframe with the same settings.
Only in Revit 2022 and newer.
curtisridenour
I have had issues like this in the past. Try printing to raster to see if it still does Wireframe.
