When joining 2 roofs of same material together, the line of the roofs does not disappear. Please Help
16 REPLIES 16
Message 1 of 17
sshamby
925 Views, 16 Replies
sshamby
I have a project where I know the low side of my roof truss, but do not know the high side. The high side will vary quite a bit across the building so to get around having to modify sub elements I created two roofs, one with a slope, and one that is flat. The flat roof sits inside the sloped roof. When I try to join the two roofs together, the lines do not disappear, even though the layers being joined are the same material. I have attached picture for reference. Typically when I join other elements with the same material together the line disappears, but in this instance it does not. I have attached some image for context
Two roofs not joined
Two roofs joined
Two roofs joined
16 REPLIES 16
Message 2 of 17
in reply to: sshamby
Almost sounds like you are describing a parapet wall the attaches to a sloped base. If so, use the Attach Top/Base Tool and check the "Base" radio button on the Option Bar.
Message 3 of 17
sshamby
in reply to: barthbradley
sshamby
No, Im just trying to get the line of the two roofs to go away when I join them. If im pulling a section i want to see the two roofs as if they were one, instead of seeing a line running through the middle of the two.
Message 4 of 17
Overlap and use Join Geometry. Join Geometry will remove volume and linework at the union.
Message 5 of 17
sshamby
sshamby
Ok, so thats my problem, I did use join geometry, and those are the results I got, when I change the join order, the layers disappear altogether.
Here is a screencast of the issue
Message 6 of 17
Share your model or at least the model of the two roofs.
Message 7 of 17
sshamby
in reply to: ToanDN
sshamby
Did you look at the video?
Message 8 of 17
It's not that hard to understand your question even without the video.  But yes I did watch it.
Message 9 of 17
sshamby
in reply to: ToanDN
sshamby
Oh ok, so no idea's then?
Message 10 of 17
Might have one if you can share the model.  Or might not.
Message 11 of 17
sshamby
in reply to: ToanDN
sshamby
Oh I gotcha, unfortunately this is a project for work and they wont let me export any revit models 😕
Message 12 of 17
Lachlan-JWP
Lachlan-JWP
Uncheck "Common Edges" under the Roof category in the Visibility/Graphic Overrides for the view.
Message 13 of 17
sshamby
in reply to: Lachlan-JWP
sshamby
Unfortunately that did not work either 😕
Message 14 of 17
Lachlan-JWP
Lachlan-JWP
Can you delete all the irrelevant elements from the model and upload it for us to look at?
Message 15 of 17
sshamby
sshamby
Sure, I was able to create the same condition in a brand new project with a generic architectural template. I created two roofs, both same materials. both same phasing, except one has a 1/4" slope and the other is flat. I used the "join geometry" command to join the roofs together, but a line still shows up in section.
Message 16 of 17
Lachlan-JWP
Lachlan-JWP
So it seems that when the base of one roof is entirely within another when you join them, then it will lose it's cut pattern. I wonder if @ToanDN or @barthbradley  know why that happens?
In the mean time you can use 1 roof with a variable layer and shape edit to achieve the same thing. See attached.
Message 17 of 17
If you cannot use one roof with edited sub-elements then offset the footprint at one end of the sloped roof outboard slightly the flat roof @Lachlan-JWP mentioned.  Below are two roofs joined together.
