when I try making aligned dimension, I can't draw it exactly.
joe-2020
joe-2020
When I make the aligned dimension, I can see the blue line on the wall(first wall) at first. But when I tried clicking another wall (2nd wall), I can't see the blue line which means I can't snap on the wall exactly. How can I solve this problem? Thanks
s.borello
You can draw a couple reference planes then dimension to those... they will not plot.
sounds like the wall is askew to the view.
joe-2020
I will check
The walls are not parallel. Fix them or use tab to snap to an endpoint. Did you create the walls based on a cad file?
