What on earth is going on with the railing.
aleena_qarni
Message 1 of 10
aleena_qarni
I'm working on the Eames House for class and after working on the stairs, the railing is not working properly. I "played" with the edit type and dimensions because it took the professor a while to get it right and I think it messed with the railing. I have no idea what to do.
Replies (9)
Message 2 of 10
Simon_Weel
Pick the stairs as Host?
Message 3 of 10
aleena_qarni
The stairs are already picked as the host. Here is more information that might or might not help.
Thank you.
Message 4 of 10
Delete it and recreate.
Message 5 of 10
aleena_qarni
Hello, I've done that several times.
Message 6 of 10
hmunsell
you posted screen shots of the Stair settings, but what are the Railing settings? (i.e. Baluster placement and Rail Structure)
Howard Munsell
Message 7 of 10
aleena_qarni
Hello, under Simon's post, I posted pictures of stair's and railing setting.Screenshot 2024-05-08 032531.pngScreenshot 2024-05-08 032219.png
Message 8 of 10
hmunsell
sorry for the confusion, those are the Stair and Railing settings, I asked for the Baluster Placement and the Rail Structure 😁
Howard Munsell
Message 9 of 10
hmunsell
if the railing is being added after the stair was placed, as I believe @Simon_Weel mentioned, you have to rehost the railing. Rehosting a railing to a Circular Stair is tricky though, You cant let the lines overlap.
start from the bottom of the stair and sketch your railing using the Arch by Center option. Don't go all the way around though. then finish it and rehost it to the stair in an elevation view. the you can maybe edit the railing and fine toon the length.
(view in My Videos)
Howard Munsell
Message 10 of 10
handjonathan
Hi @aleena_qarni
Thanks a lot for posting your question to the forums!   Has the solution suggested by @hmunsell helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
