What is the quickest and easiest way to make quantity takeoff in Revit?
Question like in topic 🙂
I have simply project in Revit and I need to create basic cost estimation and I would like to do it very simply and fast. I am using list of objects like walls but it does not work. For windows, for example, it works. Any idea?
Chris
diegoaev
well it depends. but I think you are trainig to do a material take off and not a quantity take off since you say that for windows works. Create take offs is not that simple in revit unless you are modeling the project your self, then it definetly is!!!.
Having the right wall layers, wall thickness ( depending what kind of take off/wall assembly), correct plate heights, correct end gable walls, and other parts and pieces  are what makes revit take off super fast and efficient.
Let me know if you need more help creating Material take off.
