Display Error REVIT 2017
IMCornish
Message 1 of 12
IMCornish
I have started work this morning on a 2017 project and keep getting a Display Error, see Snip below
What has to be done so that I can actually do some work?  Anyone got any ideas please?
Andrew Robertson
Chartered Architect
Robertson Partnership
Truro. UK
Replies (11)
Message 2 of 12
dzanta
that is a very generic error.  Try the following:
1.  Update graphics driver to latest driver from computer manufacturer...see if error comes up
2.  If error still shows, try reverting back to original graphics driver from computer manufacturer when system was built
3.  If error still shows, try going to autodesk website for that particular graphics card to verify it is compatible.  If so, download the driver from them
4.  If error still shows, try turning off Use Hardware Acceleration within Options of Revit
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Message 3 of 12
IMCornish
Will try that if it happens again but so far it has not reoccurred. Thanks
Andrew Robertson
Chartered Architect
Truro. UK
Message 4 of 12
IMCornish
I am having the same problem today but I cannot get any 3D view to open.  Have switched Hardware Excelleration off with no change but on turning Revit 2017 off I have a dialog with the heading "C:\Proram Files\Autodesk\Revit 2017\revit.exe"  and the  'i' message, "adui21res.dll not found".  Is this relevant can anyone tell me?
Andrew Robertson
Chartered Architect
Truro. UK
Message 5 of 12
IMCornish
An update for anyone interested.  I continue to get this problem and find that if I close Revit and open it again the problem does not reappear and the required views open with no issue.....weird.
Andrew Robertson
Chartered Architect
Truro. UK
Message 6 of 12
dzanta
Have you tried doing a repair on your Revit?
If not, try that and then try a reinstall if repair does not work.
Lastly, try a clean uninstall using the Autodesk Uninstall Tool
Message 7 of 12
IMCornish
That is interesting.  No, I have never tried doing a repair and have just failed to find mention of a Revit Repair in the help files.  How do you go about doing a repair please?
Thanks for your help.
Andrew Robertson
Chartered Architect
Truro. UK
Message 8 of 12
dzanta
Go to Control Panel in Windows, Add/Remove Programs, select Revit and choose change/repair...
Setup window will start up and you can pick Repair first....test issue after the repair.
If this does not work....
Go thru same procedure but pick Reinstall...test issue after the repair
Make sure you have Revit installation files handy to reinstall clean.  Make sure you have your serial number and product key as well.
Go to Start, Programs, Autodesk, Autodesk Uninstall Tool.  Put a checkmark in the Revit box and all programs related to Revit as well (add-ins, extensions, etc.).  Click OK to uninstall (this is a clean uninstall).
After a clean uninstall, reboot your machine, turn off antivirus, then install Revit again.
Message 9 of 12
IMCornish
I will try the repair, thanks. Thought that you meant that Revit itself had a magic repair operation rather than doing it through windows. Will try an avoid a clean install if I can because of all the associated hassles relevant to registration, file locations etc..
Andrew Robertson
Chartered Architect
Truro. UK
Message 10 of 12
dzanta
let me know your results...worse case, I can remote into your system to help you.
Message 11 of 12
IMCornish
Repair didn't work sadly so I did what I usually do and closed and reopened Revit.  This worked again but on closing Revit I got the missing adui21res.dll file dialog (see below) which I have reported elsewhere on this forum, I think; might they be related issues?
Andrew Robertson
Chartered Architect
Truro. UK
Message 12 of 12
dzanta
definitely sounds like an installation issue...do a reinstall then a clean uninstall if necessary...also do a material library reinstallation prior to clean uninstall.
