What is the difference between Project, Family and Conceptual Mass in Revit?
Hi everybody,
 I have a question about starting create some object. I want to know What is the difference between Project, Family and Conceptual Mass in Revit?
Do those things have maximum size of file?
Best Regards,
Jomthap Sukitpatthanakhun
aRcHiTeCt.JM
... you can take a look at this explanation from Mr. Paul Aubin
http://paulaubin.com/_downloads/2014_RTC/Mass-vs-Traditional-Handout.pdf
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
GHASEM_ARIYANI
Hello @Anonymous
Very simply we say|
Project: In this environment, there are basic tools to create a project, such as Wall, Floor, Roof, Stair and... The format of these files is RVT.
Family: Generally, in projects, we need components to complete it, such as Doors, Windows, Furniture and ... The format of these files is RFA.
 Conceptual Mass: It is in two forms: Mass and Adaptive Mass. Mass space is like a project space With the difference that you just design the whole volume or idea  And it is unchangeable category But Adaptive Mass space is like family space The difference is that More flexible.
GHASEM ARIYANI
BIM/VDC Manager
Revit Architecture Certified Professional
Revit Structure Certified Professional
Revit Mechanical Certified Professional
Revit Electrical Certified Professional
If my answer solved your problem, please click "ACCEPT SOLUTION" and consider giving a Kudo.
LinkedIn
YouTube
Udemy Course
@Anonymous
Here; try this one on for size:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/sfdcarticles/sfdcarticles/R...
Regarding Families: Revit has three types: Loadable, System and In-Place.  RVTs are those loadable families created in various RFT environments; Revit Family Templates.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
@barthbradley wrote:
 ...RVTs are those loadable families created in various RFT environments; Revit Family Templates.
correction:  RFAs (not RVTs)
...thanks Barry.  Smiley Wink
Thank you so much Smiley Happy
