Revit
Revit
Message 1 of 21
Revit
I'm having trouble joining the right side gable to the main roof as per the attached image. The right side image is what I have drawn in ACAD which is what I'm trying to achieve.
How can I get this to work?
Justin
Replies (20)
Message 2 of 21
aRcHiTeCt.JM
... do you  mean in between the roofs?
... if so you can draw a wall and attached both roof to that to fill the gap
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Message 3 of 21
I can clearly see that the bearing wall top plate heights (the level from which your roofs should originate) are not the same between the RVT and DWG. Also, I don’t understand the California Framing condition you presently have.  In your DWG file, I see two gable roofs on two different levels intersecting each other.  Pretty common construction.
If you want to post your AutoCAD file, I'll show you how to go about it. It really looks like the Roofs will practically build themselves once the bearing walls and top plate levels are correctly established.
Message 4 of 21
GHASEM_ARIYANI
Hello @Anonymous
Please Download and see Attached File.
GHASEM ARIYANI
BIM/VDC Manager
Revit Architecture Certified Professional
Revit Structure Certified Professional
Revit Mechanical Certified Professional
Revit Electrical Certified Professional
If my answer solved your problem, please click "ACCEPT SOLUTION" and consider giving a Kudo.
LinkedIn
YouTube
Udemy Course
Message 5 of 21
Can you please post the DWG -- not zip file. Thanks.
I thought it was the OPs file. What's in your zip file @GHASEM_ARIYANI?
Message 6 of 21
GHASEM_ARIYANI
Hello @barthbradley
Zip file is correct. Please download the new version of WinRAR. or download *mp4 format of Dropbox.
https://www.dropbox.com/s/vhavladxcom2k38/roofREVIT.mp4?dl=0
GHASEM ARIYANI
BIM/VDC Manager
LinkedIn
YouTube
Udemy Course
Message 7 of 21
@GHASEM_ARIYANI: That's one way to build a roof, but it doesn't resemble the roof that the OP is trying to build. Thanks for sharing though.
Message 8 of 21
GHASEM_ARIYANI
Hello @barthbradley
I did not want to show it exactly because I do not have time to do this. I just shared the tips that could help him to reach @Anonymous goal.
GHASEM ARIYANI
BIM/VDC Manager
LinkedIn
YouTube
Udemy Course
Message 9 of 21
You could build it as one roof. Split the footprint where the dormer is, to create two equal segments present dormer, add a slope arrow to each segment to define the dormer slopes.
Or you can build it as two roofs, use the roof dormer tool cut the main roof with the dormee roof.
Message 10 of 21
Heck, if the OP isn't trying to build the roof like the one shown in the AutoCAD file; I suggest just removing the over-framing and call it a day.  There certainly no reason I can see for it at this point.
Message 11 of 21
Message 12 of 21
Hi Barthbradley,
This is exactly what I'm trying to achieve. Can you get it to work with the left porch in place?
I've attached the Revit file and front facade image.
Justin
Message 13 of 21
see attached
Message 14 of 21
...with porch roof too.
...looks like a "California Bungalow".  Where's this house located?
Message 15 of 21
Excellent.
Although I'm having trouble working out how you've done this with the image provided.
If you have the time, would you be able to list or video this method please?
Apologies, my Revit skills are pretty fresh.
Much appreciated.
Justin
Message 16 of 21
It is in Australia.
Message 17 of 21
Hi gh_ar,
This has been helpful in learning other techniques.
Message 18 of 21
I didn't reference the image. I just opened the RVT file and edited the lower roof to cut out those sections that were underneath the roof.  Pick line method; picking the valleys created by attaching the roofs.   A little trickier on the right side gable.  Had to edit and extend the rake end out a bit, and then edit it again, after removing the lower roof portion, to align the rake with the eave.  Fairly simple.  It would be the shortest Screencast in history.
...actually, were your roofs attached to begin with? I might have edited the sketch of the right side gable to reduce its depth and extend its rake end in order to get it to attach.  Sometimes it just takes some minor fidgeting.
Message 19 of 21
I was referring to your screen shots that you had sent through previously of the roof created.
I will try and replicated what you have written.
Thanks for your help.
Message 20 of 21
Attached is another approach using a single roof with two slope arrows as I mentioned earlier.  Screencast is up in a few minutes.
https://knowledge.autodesk.com/community/screencast/aba74dcf-7d23-4077-ab87-0adbacdbbc28
In the screencast I splitted the footprint line of the dormer into two but  it's unnecessary, one line with two equal arrows will suffice.  The Revit file shows that.
