Show only
Search instead for
Weekly New Knowledge Articles by Support team | Nov 23rd - 30th, 2021
Knowledge articles written by our Revit support team to resolve the problem on your own.There're couple of incidents reported, do take a look at them for possible workarounds.
Published Date
Summary
Knowledge Article
Incident Reported
24-Nov-21
Users reported a performance drop when working with a model, specifically on a structural plan with rebars. The Detail Level has been changed from Coarse to Medium or Fine. The problem occurs especially when navigating, zooming in and out of the view in Revit.
A model initiated, for example, in Revit 2021 and saved to Revit Server 2021 is later visible when opening the Revit Server 2022 Administrator panel in a web browser. It is not listed in the Revit Server 2021 Administrator panel. The issue is related to a specific version and configuration.
How to open desired 3D view from Revit in Navisworks? Is it possible to export a specific view from Revit so that the visible geometry adjusted with filters is displayed in Navisworks? When opening a model in Navisworks, another 3D view is opened by default, even if the model was saved with the desired, most recently active 3D view.
Cannot access Revit Server Administrator panel after installing Revit Server in 20##.1 version, which supports mainstream web browsers. Loading process freezes, and folder structure and saved models are not displayed in the drop-down tree on the left.
